Old 12-22-2006   #3
Robert Venable
Robert Venable's Avatar
Re: Grinding noise when braking hard.
I've seen/heard this happen after pads have been contaminated by CV axle grease (due to busted boots) and due to a frozen caliper slide(due to only one pad grabbing on rotor causing a loud grinding vibration. I would recomend you inspect the CV axle boots for this, and if this is ok, remove your caliper and relube the slides.
1990 Mighty Max
Robert Venable is offline   Reply With Quote
