Old 01-02-2007   #11
Re: the evo 3 swap parts are coming
steve,
here is the info on it stock from mitsubishi
January 1995 saw the arrival of the Evo 3- and this time the 5000 strong production run was brought up more quickly than the Evo 2. The Evo 3 looked more serious, with its new nose moulding (to channel air better to the radiator, intercooler, and brakes). New side skirts and rear corners, while the rear wing had grown again to reduce lift. Under the vented aluminium bonnet a new TDO5-16G6-7 Turbo, new exhaust system and increased compression brought another 10ps power rise, Torque output was unaltered, apart from a higher final drive ratio. Both GSR and RS still used the same 5speed gearbox. Interior tweaks were limited to a new Momo steering wheel (GSR only) and new fabric on the Evo 2 type Recaros. The specs on this vehicle were an engine size of 1997 cc, 270 bhp@6250 rpm, Torque was 228 lb ft at 3000 rpm. weight is 1260 kg (rs 1190 kg) A top speed of 149 mph and 0-60 in 4.9secs. This model still uses the same frame. (CE9A)
