Old 03-11-2007   #2
Re: Which Cylinder head?
Your HP goals are really going to make a big difference on which head you go with. It sounds like a 2g head is going to work better for you. I would put some 272's on your list too. The reason the 2g's have more HP stock is that they run more boost stock. A 1g at the same psi makes more HP, mostly because of the 2g BOV and small T25.
I would also look at going with a Wiseco/Eagle combo. Higher compression is going to get you better spoolup and more torque. You could go with the 9.0:1 pistons and a thinner headgasket or custom order some 9.5:1 or so. How much HP are you planning on and which style of dyno?
