Old 03-11-2007   #8
Re: Which Cylinder head?
Wait then this puts the theory of JETs (sorry for picking on you) invalid.
"The reason the 2g's have more HP stock is that they run more boost stock. A 1g at the same psi makes more HP, mostly because of the 2g BOV and small T25."
How would the 1g make more horse power if both cars are running the same PSI. In theory the 2g should be making more HP because of the compression ratio.
This could go into turbo efficiency
if a 1g and a 2g were equal (exept for the compression) with the same turbo, 14b the 2g should be kicking the 1g butt. This could explain why the 14b is a popular upgrade for a 2g.
Like I said the 2g makes less power for several reasons, mainly the BOV and smaller turbo. If everything else was equal the 2g head should be making more power, lower in the RPM range. When you start getting to higher HP levels you will have to start putting some money into the 2g head sooner.
Also, "the 2g should be kicking 1g butt", I don't think you will be seeing anything that drastic. You spend most of the time in the upper RPM range while racing so the difference would be minimal.
