Old 04-04-2007   #5
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: Alternator interchange between Turbo and NA?
It works just fine!!!!!
However what did the other alternator in was that power steering fluid was leaking onto the alternator. It is still leaking! I have clamped the nut on the top of the banjo down tight.... leaks...used a washer...leaks....use a copper washer.... leaks...used gasket sealer... leaks.... What the heck is going on! I am ready to remove the power steering pump completely!
