Old 04-04-2007   #9
rst95eclipse
Re: Anyone with a valve spring compressor i can use with the head on for rent
The tool was $350 last time I saw it. You'd need to feed a long nylon rope into the chamber through the spark plug hole to ensure that the valves don't end up in the chamber - which would force you to take off the head. If I were you, I'd just take the head off, since you'll need to replace the timing belt. Why not do the headgasket as well?
