Old 04-27-2007   #7
Re: Help ASAP w/Problem
I agree with peter, set the MAFT to 550's.
You still didn't post your MAFT settings (which knobs are where)
Did you just install the afc? What does it read for Hz when this is happening? The ECU might not be seeing your MAS/MAF signal.
Double check all of your intercooler piping for leaks? Did you do a boost leak test?
