Old 05-03-2007   #11
Re: is 5 deg BTDC ok?
Tom, can you clarify some more? I think you have most of us confused now. Which timing are you trying to do? The timing belt should be set at TDC and the ignition timing should be at 5 BTDC.
Did you do a compression test? You should see if you have bent valves from the last problem.
