Go Back   MitsuStyle > Hosted Support Forums > LSE Performance
Old 05-10-2007   #11
Re: Finally getting stuff done on our cars
Pump gas, street driving, low boost... I am going to make a block off plate for the heat exchanger and run as much ice as I can(on race gase and 30+psi), about 1.5 gallons of ice will fit in the top, and use my IAT sensor to turn on the water pump at X air temp. Pump gas will be low boost, 15 or less psi so I do not think temps will be an issue. I will use a coolent temp sensor in the heat exchanger to see what the temps are, then if I get crazy put dry ice in the top with a vent and see what the temps get down to. And the hood will close, I think it will be mounted about 1" lower then it is now. The intercooler is big, the hole system will have about ~4-4.5 gallons, the water pump will draw water from the bottom go threw the IC then dump back in the top.
Pushit2.0 is offline
