Old 06-15-2007   #7
Re: Setting Up Cam Gears For A 2.4L
The problem is that they can also line up like this. See the problem? It could line up 1/2 tooth in either direction. Your cam timing is still off. Trust me, 4-5 deg of cam timing can make a big difference in spool up, low and upper end power. Depending on the cams and engine, you could run the risk of valve to piston contact.
