Old 06-20-2007   #11
Re: Drilling thermostat
Yes, go drink more jello shots.
On topic, honestly, start with a coolant system pressure check. It could be as little as a bad clamp on a TB heater hose. If you smell coolant, it's leaking from somewhere. Pressurize to 15 psi, and check for the leak. Does the waterpump have any shaft-play when you spin it with your hand? slide in and out at all?
-A. Swift
