Old 07-27-2007   #2
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: SAFC Installation Issues
did you cut the Mass wire and wire it to two wires on the SAFC The car should run like crap and have a check engine light if the safc is unhooked. does the TPS HZ and RPM show anything when your on the display screen?
Check wiring here http://www.vfaq.com/index-main.html I tihk this is for a SAFC2 if you on a SAFC or a Neo it should be close
11.35 @ 120mph
