Old 08-30-2007   #23
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: No start
This actually sound like what happen to me. Recheck the coolant sensor wiring. My sensor was fine but the wires to the sensor were like plastic, probably because of the heat. Redid the connections and fired right over. If you get your logger to work check to see what it reads. when it was disconnected it read like -76 or something. I am still guessing that is the problem especially if you are getting spark and smell fuel. Mine ran rich... smelled heavy fuel inside the car... and once in a while fired...
