Old 09-17-2007   #7
Re: SAFC2 help!
How do you know it's running rich? Do you have a wideband on the car? These cars have to run richer than most under boost.
Your Lo and Hi throttle points should probably be more like 25% and 50%. Your RPM point %s don't look horrible, most cars with your setup might be a bit farther negative, but that varies from one car to the next.
Did you actually correctly adjust the TPS? You can't just throw them on there.
