Old 10-02-2007   #5
x-pride
x-pride's Avatar
Re: Electrical Problems Gone Crazy!
The noise is from the alternator belt being loose. You will need to tighten up your alternator belt. If the noise does not go away take off all the belts and clean the pulleys. Also inspect your crank pulley. The crank pulley is two pieces the rubber in between the pulley might of cracked. If cracked replace the pulley or it might fall apart.
