Old 10-03-2007   #4
Re: Pull the Block?
Cup your hand around the cylinder and blow as hard as you can into your hands, if you hear whistling through the dipstick hole, your rings are bad.
Or just slap a good head back on and you're on your way. Rings rarely go bad in just one cylinder unless you had a massive injector leak washing down that cylinder. Sounds like everything's fine.
