Old 10-25-2007   #11
Re: Which cams?
Originally Posted by Wizard View Post
And anything over 264 grind you will need spring/retainer upgrade. Not from the revs or rpms...but the lift of the cams will cause stock springs to bind.
HKS 264s and 272s have the exact same lift. 9.8mm exh 10.2mm int
Im not so sure stiffer springs are required for HKS 280s either. At least i cant find any literature with them specifically saying YOU NEED SPRINGS TO RUN THIS CAM.
