Old 11-09-2007   #11
merkzu
Re: E85 guys, ethanol content LCD display group buy
Here's the info I got back about the backlight color:
Backlight panel on 1 x 16 characters display works with four LED diodes. Two
diodes are on the left side of the display and other two are on the right
side. Diodes glow into a piece of plastic, size of plastic is identical to
the display size and the plastic is perforated on the top side where it
touches the display panel. These perforations works like small prism and
they enable the light to exit the plastic and go through the display.
Factory LED's inside are green but the problem is that the lcd panel also
performs as a weak green filter. This color of the lcd panel occurs due to
the two polarizing filters. Another problem is that space for the LED's
inside is around 1.5mm (0.1 inch) and if leds are any other color than green
they must be much brighter in order to go through LCD system. Changing the
leds with others of different color is not a problem, stock colors are
green, yellow, blue, red orange and white, white will however pull to the
green color due to basic green color of the LCD.
So basically any color there is an LED for which should be just about anything you could want.
merkzu is offline   Reply With Quote
