Old 03-02-2004   #4
Originally posted by me612@Mar 2 2004, 08:54 PM
The bracket also has 2 electrial plugs on it, so when you're undoing all the electrical plugs and you pull those 2 off, then THAT is the bracked you have to just unbolt from the intake mani, and then you'll be cool.
Nope, that is not the correct bracket. The bracket is under the intake manifold by the firewall. The 2 bolts are on the upper 2 corners. You will find the bracket easily, it is huge. The bracket me612 is talking about would be the bracket that holds on the ignition transistor and that can stay on. I just finished up mine 10 minutes ago, so if you have any more questions, now is the time!
