Old 01-12-2008   #2
Re: Getting Back into R/C Helicopters
I can say, after being in helis, that there are some other things I'd consider. look into the raptors. v2's. I had a 30v2. GREAT beginner heli outta the box. really well crafted. assembly was easy. I'd opt for the 49bb upgrade. Also, try to get the os 32 motor, rather then the TT-39h (I think that's what they call it-comes with the heli if you get it that way). the os is more user friendly, and doesn't burn up as much. also, parts for these helis are EASILY found at most stores, and are cheaper to maintain then others ive seen. the 50v2 is the same heli essentially, just with a few different parts, longer boom, main rotor blades, (I think the newer ones come with a biffer swashplate) and a bigger motor. Other then that, it's the same. I'd LOVe to go back to the heli, when I start to fly again. also, get a good, solid 1-piece muffler for the motor. those 3-pieces from TT fall apart tons, and just didn't cut the bill.
for electronics I had the airtronics 8000 radio. 8 channel. You don't need something this fancy, but i liked it's layout and got it. For a gyro though, i'd go no further then the futaba gy401. GREAT gyro, and pretty cheap! Other then these key elements I'd say, jsut practice TONS! setting the heli up by a professional would help tons too. TRy some simulators or whatnot. it's not a matter of if you crash..it's WHEN you crash..cause, you will.
-A. Swift
