Old 01-20-2008   #6
Re: FS: O2 housing, fuel pump, FPR, & 2G TBE
I think it is confusing because of the shape of the dump tube. It looks like you'd need some sort of 90degree fitting (or an external WG) in there for it to end up pointing down and out the bottom of the car. When you look at the pics you posted, it looks like if you bolt those two directly together, you'll end up with the dump tube pointing directly into the side of your bumper cover....or is that the point? Maybe take a pic of the o2 housing bolted together, might avoid some consfusion?
