Old 01-31-2008   #1
Supa_dupa_man
Bimmer Guy
Supa_dupa_man's Avatar
Drives: ///M3
Unhappy HELP! 420A Problems!
Ok, so i ripped my motor apart this winter, and decided to rebuild it for the third time in its life, anyways the bottom end went in as normal, i used all my existing parts, except for gagskets berrings and things that needed to be replaced.
When i got to the head i did the head gasket and such, but then i decided to upgrade the camshafts (Crane #16 cams) and the cam gears (AEM tru-time adjustables), i think i installed them right, but im not %100 sure, because the only cams/gears i have ever installed were the stock ones, and i just lined up the lines to ensure that it was in time....
well anyways i finished putting the rest of the top end togeather and tried to start the car, it turned over but did not start... so i dug deeper, and found i was not getting spark, so i bought a new coil pack, i put that in today, and tried again, still wont start.... It DOES turn over, but it DOES NOT start...
im thinking that the cams are out of sync, but im not sure how to line up those cam gears so that everything runs smoothly and it will kick over....
HELP!!!
MMFTW
Supa_dupa_man is offline   Reply With Quote
