Old 02-07-2008   #12
blageo23
AWD4G64
blageo23's Avatar
Re: intake mani- skip one bolt?
I broke one of my fuel rail bolts off in my head(you should think that steel would strip out aluminum before the bolt would break) Anyways What I did was took a screwdriver or chizel and used it to make a groove in the bolt so I could try and use a straighthead screwdriver to try and get it out. OR I stuck the corner of the screwdriver into the top and hammered it in a counterclockwise to loosen the bolt. If that makes any sence. good luck with it man!
