Old 02-27-2008   #8
Re: Timing Belt on a '90 Talon TSi
I use spring loaded plastic grips from Menards to hold the belt to each cam gear. And always make sure you use a straight edge to verify the timing marks line up with the center of the bolts. I don't know how many I've seen done wrong since you can't look straight at it from the side with the motor in the car. One tooth off can make a performance difference.
