Old 02-27-2008   #13
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: Clutch hydrolic system
This may sound like the dumbest question but this is what happened when I put my ACT2600 in, engagement point was close to the ground of the car, but it was an easy fix...
you did adjust the rod connecting the petal to the master cylinder right?..
From what I understand people buy the extended rod so that they don't have to adjust the clutch or it will adjust the clutch for them, however it is easy to adjust it right at the petal.
Anyway I am just starting with the most simplest things first.
This worked for my GSX anyway
I say stay with the stock vr4 system because that system should work. I have never seen anything that said swapping master cylinders and slave cylinders to make clutches work...
