Old 03-11-2008   #11
Re: Venturi vacuum pump
As many people basically stated, can't we get the relatively same effect from buying (2) industrial check valves rated to a high PSI, that most likely work better than just the one OEM PCV, and have a "better than stock" solution to this problem.
