Old 05-19-2008   #1
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
90 talon tsi awd
converted to a 1gb talon-all parts have less than 20k on them
the ac and ps have been removed
mods as followed
computer-
90 eprom w/ dsmlink
engine-
weisco pistons
eagle rods
arp head studs
arp rod bolts
acl race bearings main/rod
head-
ported and polished
ss stock size valves
bronze guides
crower single valve springs
crower titanium retainers
bc 280 cams
3mm revised lifters
fidanza adjustable cam gears
turbo system-
turbonetics t3 manifold
tial 38mm wg
ebay front mount
dejon tool upic w/ gm mass adapter
gm maft
fuel system-
twin in tank walbro 255's
pte 1600cc injectors
aeromotive adjustable fpr
exhaust-
totally custom for the car
2.5 to 3in dp
3in back
brakes-
2 piston conversion
ebc green pads
ebc slotted and drilled rotors
stock rear brakes
suspension-
agx adjustable shocks
eibach sport springs
adjustable rear control arms
energy suspension poly bushings (only front control arms installed)
transmission-
tre w/ double synchro 2nd gear
welded diff and tall 1st and 5th gears
act 2600 clutch w/ fidanza street friction plate
act flywheel
stereo-
jenson 7in tv deck,ipod ready (little messed up from recent try of stealing the radio)
ma audio 6 channel 1600 watt amp
audiobahn 6.5in rear speakers
interior-
4pt roll cage
4pt harnesses
checker race seats
autometer monster tach w/ shift light
autometer oil,boost and egt gauges
hks type 0 turbo timer
sparco shift knob
tires-
oz racing 5 spoke 17 in rims
the good-
new timing belt
crank and bearings
4 bolt rear end
the bad-
turbo is bad (journal bearing gt3582)so its not listed if you want it i'll give it to you $500.00 to rebuild
typical rust spots on the car at the rear quarter panels, front off hood
has a dent right by the ds tail light that has some rust on it.
looking to sell as a whole unless i get enough people that want parts off it.
car is tuned on e85 made 408awhp on a bad tune, car was re-tuned but spun 2 bearings and still made 428awhp at 33psi gate is set at 25psi
6000.00 for everything the parts alone are worth twice that
