Old 05-19-2008   #13
mdost03
Sonic Champion!
Drives: VA STI
Re: Please help, leaking coolant
Also while you're in there, that coolant pipe should have a spot for a bolt to hold it against the block, right under the exh manifold. Make sure that bolt is in there holding that pipe in place so you can be sure it doesn't pop out.
Yep, got that in there. Made sure to apply some pressure on the pipe and then secure the bolt to get a nice seal.
