Old 05-30-2008   #10
Re: SAFC Installation and Settings Help
The SAFC 2 has 1 extra wire for knock, which was so useless that they dropped that feature in the SAFC Neo. Just set the high - low TH-point at 25% and 50%. Then set every setting in the low throttle RPMs and high throttle RPMs to -12%, except for around idle (low throttle and usually 1000RPMs). Set the idle area to something like -5 or even 0. Then just go very easy on the car until you can get it tuned. The O2 sensor will compensate a lot at idle/part throttle, so you just have to be somewhat in the ballpark and it should run fine.
