Old 07-01-2008   #10
Re: To remain stock or not to remain stock
Originally Posted by bertrenolds5 View Post
Halon, I can use my stock FPR with bigger injectors and fuel pump? I thought you had to adjust the fuel pressure so your car doesnt run to lean or to rich?
Yes you can. You don't need to even consider upgrading it until maybe you go to a 255 pump. And even then, you can still get away with the stocker.
You really won't be adjust the fuel pressure at all, you'll use DSMLink for all your fuel adjustments.
