Old 09-29-2008   #6
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Re: 1g 6 bolt awd auto to manual swap parts
... How did you pull that one off because there is a cable that runs from your shifter to your ignition that keeps you from pulling the key out unless your in park. And that little lock thingy is just a little lever that is pushed up or let to fall down by said cable, and if it falls down your key is stuck in the ignition. I learned this from first hand experience after removing the cable and then putting the key in and I couldnt get it out.
