Old 10-02-2008   #21
viridionplague
Re: People are IDIOTS! - E85
i think the best thing you can argue is the fact that alot of people get ethanol mixed up with methanol
methanol being highly corrosive.
also there is around 10-15 % ethonal in normal gas, and there has been debates for a while about raising the ethanol content of regular gas to as high as 50%
Since 1977 the government made mandatory to blend 20% of ethanol (E20) with gasoline
as somone stated before the bigger injectors and fuel pump is to account for the added 30% usage
you also need some kind of tuner, for one to account for the 30% and also to account for the different burning caracteristics of e-85.
e-85 burns more efficiantly and cleaner.
another thing to note is lean / rich mixtures of either fuel. stoic (ideal) afr's for gas is 14.7 and for e-85 is around 9
as well if you look at octane ratings, the highest you can normaly get at a pump is 93, thus limiting boost or compression depending on application.
where e-85 is normaly around 105-110 helping prevent detonation at higher boost levels or higher compression levels
