Old 10-27-2008   #2
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: hks adj cam gears, issues with setting up timing. Help
Dont go by the upper marks. Just make sure the dowel pins are pointed up like they are.
If you can run a straight edge across the center marks between the gears you should be ok. Just make sure everything below is lined up as well. Turn it over by hand a good 6 times until everything lines back up again, oil pump included, just to make sure everything is good.
Originally Posted by shoutbox
