Old 12-17-2008   #2
Re: Valves hitting pistons
It depends on how bad the pistons hit. Put up some good close up pictures of each piston. It will create a weak spot in the piston, if the car is only going to be pretty stock, they are normally ok with a light hit. You will want to file down and polis the lip that was created with the hit. It might be a good time to freshen the engine and put in some 2g pistons too.
