Old 12-22-2008   #30
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Drives: 1990 Eclipse, 1991 Eclipse with a little Holset Sex
Re: T3 vs. Mitsu housing
Which compressor wheel does each have? The 7blade 56mm compressor wheel will spool the same as the 8blade 56mm compressor wheel using the bep housing. It flows 60lb/min. If if you want more turbo later you can get the t3 bep housing or use a used 12cm^2 hx35 turbine housing (t3 bolt pattern) and have enough turbo to make 570ish whp. And with either turbine housing spool will be between 3900 and 4100rpms.
EDIT: To add, if you stick with bolton . . . In the meantime, you will have a turbo that will spool as fast as an evo3 16g/td05h 18g/tdo5h 20g, but flow as much as a td06 20g or t31 50-trim.
Matt
Bolton Holset H1C w/ external gate, fp2X cams, DSMLink, 3" exhaust, FMIC, water injection
"There is nothing better for man than to eat, drink, and see good for all his hard work." Solomon
wheelhop is offline   Reply With Quote
