Old 01-18-2009   #1
Logging IAT/MAT (Manifold air temp) on stock ECU
Not long ago I had my IM off while doing a headgasket, so I took the opportunity to tap it and install a GM IAT sensor.
Using a hack from evoM, I can now log manifold air temp on the stock ECU using a GM IAT sensor. Works great! This will be an invaluable asset for tuning, and combined with my 3-bar map sensor, guess what's next?
Log results from a good 3rd gear pull:
Orig info:
http://forums.evolutionm.net/ecuflas...t-logging.html
