Go Back   MitsuStyle > Hosted Support Forums > Brookdale Mitsubishi
Old 02-24-2009   #3
Re: evo turbo stuff
Slight modification:
Originally Posted by Nick G View Post
manifold gasket mr323654 $21.38 in stock
turbo gasket 1515a184 $33.28 need to order *bends over* ok.....do it!
o2 gasket mr299686 $9.70 in stock
manifold to turbo studs mn119784 $7.34ea x2 need to order <--SKIP
manifold to turbo bolts mn119783 $2.74 ea x2 need to order x4, I'm going to replace the studs!
oil feed washer to head mf660063 $1.02ea x2 in stock
oil feed washer to turbo mf660064 $1.22 x2 in stock
oil return gasket mr258477 $1.16 need to order
oil return gasket 1226a002 $1.52 need to order
water feed hose md363256 $3.34 nee to order
water return hose md082347 $3.16 need to order
coolant washers mf660065 x4 $0.72ea in stock
thank you!!
Nick
Also you forgot the trunk clips, can you get those too please? Can I get all this stuff by friday?
