Old 03-07-2009   #11
Re: Make slowboy not so slow
Not unless you want to deal with it possibly pushing coolant. The Permatorque is sticky like fly paper and the Cometic MLS comes with it's own kind of coating on it that will likely stick the head and block when you remove the head. You could be ghetto and copper spray the MLS and try to reuse it. The Mitsu MLS would be the easiest one to try to reuse.
That will be checked when the head is off.
Noob question, can you reuse any types of headgaskets, like the permatorque or cometic mls? Like if I take the head off, turns out seals and guides are terrible so I fix that and reinstall the head. But then I need to take it apart again to also do the rings.
