Old 03-25-2009   #11
Re: Little. Blue. Different.
Are you POSITIVE the timing belt isn't off a tooth? That could explain it. Compression seems decent, so that shouldn't be it and if you had the head done, then the leak down should come back ok unless the rings are shot, but that isn't real likely. I am sure you have done a boost leak test, right?
