Old 04-02-2009   #5
Mwolf83
Drives: 91 Eagle Talon AWD, 02 WRX, 97 Civic Hatch
Re: ARP and rod bolt questions
80 seems low, I thought a lot of people did 90-100 range, but I'm probably wrong. Does it depend on the power you want to make? Or the type of headgasket you're using?
Also what is the proper sequence (6 bolt if that matters)?
80 does seem low, but its not. When using the moly lube you dont have to torque it as hard to get the same amount of turning on the nut.
Mwolf83 is offline   Reply With Quote
