Old 05-04-2009   #11
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Drives: 1990 Eclipse, 1991 Eclipse with a little Holset Sex
Re: My Talon
OUCH!
You can get a wh1e to bolt into your hx40 turbine housing. It has a 58mm 8blade compressor. Or just a standard 8blade 58mm inducer hx40. You don't need that 7blade or 6blade 60mm wheel. Not remotely for your horsepower. 8blade hx40, 535whp on a dynapack and 139mph with 2760lb race weight: Click. You have another 100hp to go before you should wonder about having the 60mm wheel. That could save you some $$$.
. . . Research holset fakes if you decide to get another holset. There's chinabay fake hx40s floating around. There's a thread on tuners about it. The word holset in the same font on the id plate that looks like a holset plate on the compressor cover and all. "xs power" pops up when you move the mouse over the pic. . .But You can spot the difference easily if you know what your'e lookign for. Holset is even pressing the issue with the authorities. Just a heads up if you're looking on ebay for a real holset.
Here's the thread. Click.
Matt
Bolton Holset H1C w/ external gate, fp2X cams, DSMLink, 3" exhaust, FMIC, water injection
"There is nothing better for man than to eat, drink, and see good for all his hard work." Solomon
wheelhop is offline   Reply With Quote
