Old 04-12-2004   #1
tsiawdspeed
tsiawdspeed's Avatar
Send a message via AIM to tsiawdspeed
I installed my new suspension consisting of AGX's and Prokits in my car (2G) this weekend. The ride is pretty damn nice. It handles a LOT better. Almost no body roll on some corners. It looks a whole lot better. I also got an alignment and everything is where it should be except for the camber which is off by .5 degrees. One strange thing I noticed is that the rear shocks are only 4 position adjustable and you adjust them on the top of the shock shaft just like the fronts. Also, if anyone knows the length of the stock 2G front shock body, could you let me know so I can compare to the length of the front AGX body? I know the new style 2G front AGX is noy at least the same length as the stock shock if not shorter. And if anyone is wondering, the new correct front shock part # is 741042. Anyways, I thought I would share with you guys :3gears:
tsiawdspeed is offline   Reply With Quote
