Old 06-25-2009   #25
ItTricky
Drives: 92 Dodge Stealth ES/RT/TT
Re: AC recharge
its ridiculously easy to convert to 134, we did it in a protege the other day and it took 10 min, i went to advanced they have the entire kit there for like 26 bucks, you screw on 2 new fittings over the old ones and fill it with 134, you just have to make sure all the r12 is out. You'll probably have to unhook the low pressure sensor though so your compressor will cycle it through at first as we had to since when its too low of pressure it won't cycle so id doesn't burn out the compressor.
ItTricky is offline   Reply With Quote
