Old 07-15-2009   #28
v8klla
v8klla's Avatar
Re: Having overheating problems
Chris,
As we have said MANY times if something that we did is causing this issue you will not be charged to rectify it. On the other hand, your car is approaching 15 years old and there are many components that we did not touch / replace on your build. You paid us to replace your short block, assemble it into a long block, and get the car running which we have. If you would like us to rectify this cooling system issue we will do everything in our power to do so, but I simply can't understand why you think we should do this work for free if it has nothing to do with the work that we performed? Also, the suggestions we made in regards to replacing the radiator and fans were exactly that, suggestions. When trying to diagnose an issue like this there is no way we can be 100% certain that our suggestion will rectify the problem. With that said, regardless of whether or not moving and rewiring the fans rectifies the situation we will need to be compensated for our time. If there is any issue with this please contact me immediately so that we can stop working on your car.
Chris Carey
763-545-3800
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
