Old 07-26-2009   #7
john
Business as usual
john's Avatar
Re: Apexi Old School SAFC FS
More or less looking into how to hook it up. Since the harness is cut.
The harness being cut isn't an issue. There is plenty there to make it useable and there wasn't any special connector from the get go. You will just pull the plugs off the ECU (located behind the radio), tap the correct wires and cut and splice the fuel signal wire, mount the controller, and tune.
Bigger issue may be finding the correct wiring diagram for an old unit like that. If I remeber correctly, Apexi had a nice site with instructions on it.
97 Viper GTS
