Old 08-07-2009   #1
redline
redline's Avatar
Drives: GSX
Hub ring question...
I am trying to get rid of a 60+ mph slight vibration and after mounting new tires and a balance, it is still there. Just got the car and it has aftermarket rings that have no hub rings on them. Best I can measure, my micrometer sucks, the hub side is 60.06mm and the rim bore is 67.10mm. Most guys I have called to order rings are saying the size sounds pretty unusual and most are a 73mm hub. The rims are Enkei's, but not sure on the model. can't seem to find the rings other than special order, anyoine know who carrys them local and what the standard hub size is on a 2G gsx?
redline is offline   Reply With Quote
Old 08-07-2009   #2
96GST16g
livin the dream
96GST16g's Avatar
Drives: 07 zx6r and 04 Rx8
Re: Hub ring question...
is it awd?
Old 08-07-2009   #3
redline
redline's Avatar
Drives: GSX
Just found out part of my problem with that... It was a gst and converted to awd... the front brakes are still the smaller gst size....
Old 08-16-2009   #4
97spyder82
Drives: fast
hey redline how did those hub rings work?
97spyder82 is offline   Reply With Quote
