Old 08-19-2009   #28
iceminion
iceminion's Avatar
Re: How to swap heads quickly.
Its actually a hydraulic rod that provides tension over the length of a typical belt cycle/revolution. If the tension is not correct to begin with (on the pully/tensoner rod not centered) it is very likely that the tensioner will eventually run out of range and not compensate on during a high rpm condition, or start-up/shut-down stress.
Correct, an auto adjusting tensioner.
building a 3000GT AWD Turbo.
