Old 09-01-2009   #11
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: New DSMer here!
Originally Posted by DSM91TURBOTALON View Post
Thanks for the compliments guys! The car came with the paint job, i havn't seen a DSM the same color yet so i guess it makes it kinda unique. And it is a FWD in need of a turbo tranny lol. The mods are K&N air intake, straightline specialties intake pipe, bigger intercooler pipes, HKS SSQ BOV, Halman pro MBC, custom heat shield, ACT 2100 clutch with street discs, short throw shifter, new 14B turbo with pry about 8k on it, full 2.5 inch exhaust with no cat and a 5 inch can out the back, K&N breather filter and ARP head studs. Also it has KYB adjustable AGX's all the way around with 2 inch eibach drop springs. There might be a few more that im forgetting and internals on it are unknown. What do you think i should do to her next? SAFCII? And any guess on how much Horsepower im putting out?
If you need a trans I would do that first. Are you still on the NT trans? If you swap over to the turbo trans you'll need a turbo clutch and flywheel and starter plate. Also make sure the trans is a 90-91 so you can keep the same axle shafts.
After that, I guess the sky is the limit. I would do a nice fmic kit, go with some injectors and a fuel pump, safc2 or a maf-t and max out that 14b.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
