Re: How to swap heads quickly.
The bungy cord method worked well enough for me. I was able to swap my head off and back on it a few hours. I used to zip tie the belt to the cam gears in many spots, use the bungey cords from the hood to the top of the cam greas to keep the tension and stick something between the cam gears. Worked well enough that I wouldn't use the time to make a tool. Removing the timing components on a dsm isn't that tough though. Everything is right there after you remove the covers.
7/25/09
