Re: wont start
7 bolts dont have a CAS. They got a cam position sensor thats under the timing cover.
If you guys did the timing, the cam position sensor could be to blame. If its the factory one, the wires are almost always toast and just looking at them wrong will make them snap and cause a real headache. Mostly cause you got to the pull the timing belt and maybe a cam gear to get at it. Rent a scanner from the parts store and see if a code pops up.
The wires for the crank sensor are the same way and would probably cause a no start too.
The other fussy bitch is the connector for the transistor pack. Make for sure that its completely plugged in. It actually takes a bit of elbow grease to make sure it clicks. The MAS can be the same way.
